Screws for 6mm ply
Discussion in 'Carpenters' Talk' started by kemical, Feb 1, 2008.
  1. kemical
    kemical New Member
    Hi
    I’m about to lay some Plywood 6mm over a chipboard floor 18mm to even it out.
    What type and size of screws should I use for the above?
    How far apart should the screws be screwed?
    Thank you in advanced
  2. jasonb
    jasonb New Member
    20mm will do the job and won't go through the bottom of the chipboard into any pipes etc.
    Around 200mm centers for spacing.
    Jason
  3. kemical
    kemical New Member
  4. jasonb
    jasonb New Member
    Go upto a 4.0x20 in either of those types the heads on the 3.0mm ones are a bit small and may pull through.
    Jason
  5. kemical
    kemical New Member
    Hi
    Thank you for that
  6. jaygee45
    jaygee45 New Member
    Is pre-drilling or countersinking needed for the 4.0x20?
  7. malkie129
    malkie129 Well-Known Member
    I had no need when fixing my floor, but I used 9mm ply . Straight in....No probs. :D
  8. malkie129
    Should have mentioned that I did use 4 x 25 screws. ;)
  9. chippie244
    chippie244 Well-Known Member
    They may self countersink or not, try it and see.
  10. jaygee45
    jaygee45 New Member
    Self countersinking working as long as angle is true. Keeping with small heads even with risk of pulling through. Thanks for advice
