Hi I have a bit of a query regarding the use of self driving wood screws , the joiner doing my stud walls in a new build is using the full thread Screws with no shank to screw 70*50 timber together , now my question is how can the timber be pulled together if there is still thread in both of the joints , I would of thought that the timber to be screwed on would need a screw with a plain shank ( attached pic ) at least longer that the depth of the timber to be fixed , otherwise it will not be able to pull into each if there is a thread of the screw in both joints ! .
Modern screws are fantastic on wood like the stud work you mentioned and with a little help from an impact drill its icing on the cake. I have one dislike only my opinion they are realy dedicated to wood . So I still use std cheap as chips screws for wall plugs and chipboard as the fixing appears stronger . I would like to see your face if you saw metal stud being used .
