Shaver point buzzing
Discussion in 'Electricians' Talk' started by Retlas, Sep 1, 2016.
  1. Retlas
    Retlas New Member
    Hi, I have a shaver socket that buzzes and is slightly warm all the time ( when not in use) I assumed that when not in use they would be dead. As I have two and the second one does not make a buzzing/ get warm do I have a problem.
    Advise would be appreciated
  2. Pollowick
    Pollowick Screwfix Select
    Depends on the type/brand. On some, the transformer is permanently energised and a small amount of power is used which creates the warmth you can feel. Others, have a switch or detector on the input and they are only energised when a device is plugged in.
    The buzzing is often caused by a a component being loose or transformer laminations slightly separating which means that as the 50Hz AC continually changes the magnetic field there are vibrations at around 100Hz which is what you can hear.
  3. Retlas
    Retlas New Member
    Many thanks
  4. Smokey
    Smokey Active Member
    Assuming it's a traditional (Toroidal ) not electronic transformer, could well be harmonics vibrating; have you looked inside to see if practical to mount the transformer part on rubber washers to absorb the vibrations?
  5. Pollowick
    Toroidal - you must be joking. Everyone I have seen uses cheap E-I laminations.
    TP&N likes this.
  6. Bazza
    Bazza Screwfix Select
    Change it for an MK one. They only energise when something is plugged in to the shaver socket.
  7. Pollowick
    And make sure it is the newer MK one ... they will do electric toothbrush charging too.
  8. nigel willson
    nigel willson Screwfix Select
    replacement time
  9. Bazza
    I thought I had suggested that! ;)
  10. Retlas
    Retlas New Member
    Thank you all, very helpful. Turns out that the unit has little flaps behind the plug holes and when they are open with the plug the unit is activated. The little flaps were stuck open from the last use and when the clicked back the buzzing stopped and the unit cooled down. I will buy a new unit.
    All the help enabled me solve this matter and learn something, so again thanks all.
    R
  11. Pollowick
    What brand? Some, such as MK have 10 year warranty.
  12. TP&N
    TP&N Active Member
    Sticking shutters , a job for a little and I mean a little Silicone grease, Or a little Mr Sheen that stuffs full of silicone.
  13. tina lucinda lane
    tina lucinda lane Screwfix Select
    hope the power was off or you used something plastic to poke the shutters with
  14. Bazza
    Could he get a shock from doing that? Surely the reason for UK 'shaver points' is their separation from the earthed supply side.
  15. tina lucinda lane
    metal object into the live pin socket i though you become the earth but hey you want try that go ahead then tell us what your hair dresser charged you for re doing your hair do (know i wouldnt take the risk)
  16. Bazza-spark
    Bazza-spark Screwfix Select
    Alex, these sockets are supplied via an isolating transformer so there is no path back to earth. Exactly the same as the transformers used for power tools. The only risk of shock is via line to neutral on the output side.
    Kind regards
  17. Bazza
    That's because you are a bit short of understanding. Maybe this will help
    [​IMG]
    You cannot get a shock from that. As my alter-ego says, there is no path to earth. You are just like a bird on a HV cable. No shocking experience.
    Your only shock opportunity is to shove one metal thing in one socket hole and another into the other hole and grab hold of them both.
    sparky Si-Fi and Bazza-spark like this.
  18. Bazza-spark
    Nicely done.
    Kind regards
  19. ZeZs
    ZeZs New Member
    Replaced a faulty shaver socket today, went for an MK. The shaver socket was wired directly into the lighting circuit, no independent isolator. Nothing unusual about that, it was done a long time ago......
    Driving home and i am trying to decide if I should, to keep in line with regs, install a switch.
    In an ideal world I would, no problem, but customer does not want the additional expense.
    Thoughts and feelings appreciated.
    Thanks.
  20. sparky Si-Fi
    sparky Si-Fi Screwfix Select
    Could do with a dual 230V outlet on them and ditch the 115 for the UK market, I mean who still uses electric shavers! 'orrible things
    Its a pain in the **** as its sat there looking at ya with two toothbrushes on a swop shop routine
