I fitted a 760x760 shower tray against new drywall, then had a tiler tile the walls. I then bought a 760x760 shower screen, but it's too big because of the tiles. I'm sure I read that the tiling should be completed before installing the screen/shower etc. Can anyone give me some advice?
Generally speaking the tray lips under the tilework as you've described.The enclosure is fastened to the wall by two uprights, plum and level, and the screen(s)slide in and subsequently held with self tappers.Adjustment is normally by way of sliding the enclosures in or out of these wall mounted uprights. If you've got the screens firmly into the uprights and it's still too big then the tiles must be mightily thick (or heavy on adhesive to level the walls)or indeed the tray and enclosure sizes don't match. Hope this helps.
Thanks for your advice. I think it's best that I re-site the tray, leaving a 10mm gap between the tray and wall.
Try and swap the screen, look at it carefully - some adjust UP TO 760mm and some adjust DOWN TO 760mm , you need one that goes UP TO 760mm MAX.
mcluskc I understand your upset ..most tilers will say the tray is wrong sited before tiling down to it ... just resit the tray if way off altering the screen , an retile the lower tiles, pay peanuts you get munkeys.. lol
All the shower screens I've fitted say fit after tiling. Why, I don't know but they do. IMHO, I'd say it's better to tile after fitting but they say no. I know you can buy shower screens that are adjustable, from about 720mm to 780mm. I have just fitted two for a customer who got them from SF, however, I've just looked on-line and can't find them, my SF book is in the van and I can't be bothered to go outside in the rain to get it.
an the point/ post was ?????? you use screwfix Big Hand Clap for the SFD Maketing man here .. coughbetter shower elsewhere cough
