hi if you want high flow rate for hot water, its either from stored hot water or very very high Kw electric boiler. rule of thumb, 30Kw will give around 12 lts/min delta t 35c if you can find the rate of flow that the tower shower requires, it can be supplied by the correct size electric boiler ie Amptec boilers any thing is possible! regards peter
