Regrettably, I've bought the following shower tray from Screwfix https://www.screwfix.com/p/the-show...d=296529#product_additional_details_container It was supplied with a shower waste that will not connect to the rest of the 40mm FloPast solvent weld pipework I have installed Can anybody (Screwfix?) identify the brand of the supplied waste trap please Thanks in advance
Try and avoid using the flexi waste and use solvent weld pipe straight into the trap. The compression fitting on the trap will accommodate the pipe fine and dandy
As already well mentioned above,use pipe instead of that snakey fitting. Or get a Mcalpine 40mm flexi waste but try it in the trap before leaving the trade counter.
Tbh, the majority of 'free' traps are pretty poor and I sling them in the bin and fit a mccalpine or similar.
Dont know what size your trap is but i avoid the mushroom cover types in favour of the standard petal or slotted.
