Need to replace some Silver / Grey kickboards that are water damaged Do you know which manufacturers supply them? The inside of the cabinets are the same laminate Cheers Nigel
As you've probably found out, you wont be able to buy this board from any of the major sheds Try your local directory and look for a kitchen/bedroom manufacturer, usually a few on local trading estates They will have a huge range of board colours to choose from, silver included (often used inside drawer packs) Will be able to cut to size for you if needed, I would imagine
Go for stainless steel, never affect by water,like mdf,wood, so can't rot, you can get matt, satin & mostly likely gloss finishes. Several styles available either like that below in link or flat sheet 150mm x 3mtr or 4mtr lengths, & you get joiners, end caps, rounded corners,etc. http://www.onlinekitchensuk.co.uk/o...ign=original&gclid=CKebuNzbz84CFdVAGwodxBcIKg The sheds like B&Q can supply mdf back stainless effect plinth for home delivery, not available in store.
kitchen door workshop http://www.kitchendoorworkshop.co.uk/free-brochures-and-pricelists/ can supply a stainless steel looking plinth. Its faced onto a plastic twinwall board rather than mdf so is waterproof.
