Fitted new kitchen cabinets. Want to have a low light glow under them but nothing bright..Just to add a little splash as kitchen dull in a few places. Mains or battery under cabinet leds ive see seem a bit bright. Anyone know something not expensive and only small glow?. I know there are stick up lights but each needs battery ang guess batteries dont last long?. Any thoughts? Thanks.
Thanks for valued replies. I have location in different parts of kitchen and dining. Ideally would want 5 off at 1 metre length. If it keeps cost down then just blue colour leds. Suppose best also being each 1 metre strip with own plug. Suppose its too much to ask where they are usb powered and could slave each off a 3 pin plug thats got a usb slot also inbuilt?
In lengths of 2M - 3M - 5M, LED Lamp Flexible Strip Light 60/M IP67 Waterproof Warm White. From e bay. I got 2 by 5mtr for £14.
These LED strips are commonly 12v, so they require a transformer(I.e they are not mains voltage) USB is 5v and there are certainly strips available in USB/5V variants.
Not for under cupboard lighting, but I have them behind my TV. They are very bright and you would not notice the difference between normal 12v ones and the USB ones.
I have the same as master diy but mine are under the wall cupboards and are fully dimmable ,and able to colour change ,flash ,fade in and out etc etc . When im able to shrink a pic to the right size i,ll show you ! Won,t let me upload at the moment .
