Hi all, I thought I'd try the American idea of tapered boards and joint filler but I'm not happy with how it's turned out so I want to plaster over the lot. Sooooo my question is - how do I prep the wall before plastering? Give it a couple of mist coats? Pva/water mix? Ta muchly p
Scrim joints then pva over any filler before skimming, otherwise the filler will be sucking moisture out of your skim.
Thanks all - I put scrim tape over the boards before the joint filler so wouldn't need too again?? Should I use watered down pva or put it on neat? Ta
Is the filler not fixable with a good sander ? You could hire a pro kit for a day https://www.hss.com/hire/p/drywall-sander-kit
http://www.powertool-supplies.co.uk/festool-long-reach-sander-lhs-225-eq-plus-ip-gb-110v-planex.html Might be out of OP's budget though...
Panta, if you haven't skimmed before, welcome to a huge learning curve... Watch some vids on PooTube to get an idea, and then commit yourself to it with gusto... One main issue as said above - the existing plaster skim over the tape will be bone dry and very absorbent, so will suck all the water out of you new skim coat in that area - the skim will go lumpy and crumbly and be a 'mare to deal with. You could try PVAing it beforehand, but this can go the other way too much - be less absorbent than the surrounding bare boards. So what I tend to do in situations like this - where I don't want to PVA everything - is to dampen the dry plaster with a hand-held spray 'mister' like wot you use on plants. Give it some light misting until the worst of the 'instant absorption' has stopped, then you should be good to go...
Don't know about the OP but out of my budget Although the Rotex coped very well, a bit heavy for ceilings but a fantastic job, could actually sand comfortably across the board and not remove the paper so instead of knocking of the odd blob or splatter with a scraper, just sanded them off
Very valuable lesson. Doesn't matter how easy a spread makes it look, it's not. I'm also speaking from experience
Making up the mix and then the race to get the stuff on the wall and get a good finish before it goes off ! Its one of those things that needs a lot of practice, not just to get the finish good but also the speed and the arm muscles. A chippy mate of mine can get finishing plaster to a marble like sheen but won't paper a ceiling .... horses for courses
For me it's the finish of the plaster. Anyone can slap some plaster on the wall, but it does take some skill to get it flat and without trowel marks.
