Hi I want to order matching skirting and architrave and I want to make sure it is finished properly where it meets at the skirting. I like the look of Ogee. Do I need to order anything extra (I've been googling and seen something about a 'block' at the bottom of the architrave)? I'm dreading having a load of filler to cover gaps. Can we get a neat join between skirting and architrave or do I need to order something to give a nice finish? Many thanks Terry
As chippie said, isn't needed but really depends on what spec finish you would like to achieve, I have made up blocks in the past incorporating architrave block mouldings which can look a 'cut above the rest' if balanced properly.
I wouldn't bother with a block, fit arches first then skirting,scribe the corners in. Shouldn't need to fill much
