Skirting Board opinions - patterned or just square?
Discussion in 'Carpenters' Talk' started by Matt_H, May 9, 2017.
  1. Matt_H
    Matt_H Member
    Hi, I have just had the walls plastered in our refurbished living room and am now ready to install the skirting board.
    I want the room to look modern.
    I personally think patterned skirting boards look old fashioned. I am thinking of getting just square MDF skirting board with no curve or pattern, like the one shown below:
    http://www.skirtech.co.uk/Square_MD...ct--407.html?gclid=CNXxv9X04tMCFe-d7QodtgYJAQ
    Am I right in thinking this is the style more modern houses would have?
    Thanks
    Matt
  2. KIAB
    KIAB Super Member
    Matt_H likes this.
  3. vivaro man
    vivaro man Active Member
    Matt, yes it can look quite effective but I think it's a fad rather than anything startling. There is a certain timeless class to some mouldings. Look in some Edwardian houses they have huge 10inch skirts and they look brilliant but they had 10foot ceilings.
    Can't go wrong with ogee, torus or like KIAB says pencil round. They have all stood the test of time, they are readily available and they do look good when properly fitted. I'm not entirely convinced that an 18mm flat top might not become a dust trap. Mrs Matt might have something to say about that.
    Good luck.
    Matt_H, Jord86 and KIAB like this.
  4. If you are not careful, 'flat' could look very cheap and basic. I guess, done right (colour scheme, etc) it could look good.
    I think the best suggestion would be to surf pictures of actual installations so's you can see them in situ - only then will the true effect show.
    Lots of options to completely flat if you want modern - Manchester & Rebate (second link above) for two.
    Try Google images.
    Matt_H likes this.
  5. dwlondon
    dwlondon Active Member
    Any flat surface soon becomes grotty and dusty if not cleaned. so skirting with a profile reduces this appearance.
    Matt_H likes this.
  6. Matt_H
    Matt_H Member
    Thanks All...I'd not thought about the dust issue.
    KIAB likes this.
  7. KIAB
    KIAB Super Member
    Regardless of profile all skirting will collect dust.
    Deleted member 33931 likes this.
  8. Jitender
    Jitender Screwfix Select
    I try and keep skirting the same throughout the house, matching existing stuff.
    Have 3" chamfered skirting, it is reversible with bullnose on the other side.
  9. The dust is the least of it!
    Fit what you feel will look best. That's it.
  10. GoodwithWood
    GoodwithWood Active Member
    I hate reversible skirting with a passion. Prone to cupping in pine, less material to bond/nail to, and worst of all you don't have a flat surface on the bottom to strike a line from a square or sliding bevel. HATE, HATE, HATE them. The only one to benefit is the retailer as it takes up less space and saves buying two products. I refuse to fit it. It's worse than having to remove slotted screws from old painted over hinges. lol
  11. Astramax
    Astramax Super Member
    Leave it off....................less to paint!;)
  12. masterdiy
    masterdiy Screwfix Select
    Matt, would it help you if we all took a photo of our skirting's, then that might help you to chose.??
    I dont know if my Misses would say anything about that. Will have to clean off the tops first..:eek:
  13. PC Works
    PC Works Member
    The only issue with having patterned skirting boards is if you have to replace a section somewhere down the line, you might struggle to find the same pattern.
  14. masterdiy
    Easy, Buy double the amount. Store it in the loft. Simples. ;)
    Astramax likes this.
  15. PC Works
    PC Works Member
    Won't be enough room with all the bodies surely.....
    masterdiy likes this.
  16. diyjase1980
    diyjase1980 New Member
    Yep - can't beat the standard MDF. Get it pre-painted and it makes the job so much easier too!
  17. Astramax
    4 year old post......probably done and dusted by now! ;)
    BillyBobToo likes this.
