Sourcing Cheaper Materials
Discussion in 'Builders' Talk' started by Chris Bartley, Oct 18, 2014.
  1. Chris Bartley
    Chris Bartley New Member
    Hi just wondering if any of you guys could point me towards cheaper materials for my extension. The likes of Travis' seem quite pricey.
    Im looking for:
    Thermalite / Celcon 100mm 3.6n blocks
    Concrete 100mm 7n blocks
    Kingspan K8 50mm Foiled Cavity board
    Also will need loads of timber for big cut pitched roof.
    Thanks in advance, any help will be greatly appreciated.
    Chris
    Gillingham, Kent
  2. Phil the Paver
    Travis are by far the dearest merchant around, have you got a Selco in your area or even a local independent merchant.;)
  3. Phil the Paver
  4. Chris Bartley
    Sidcup isn't too far away. Ive never used Selco? Are they reasonably cheap?
    Ive just filled out the online application form.
    Any other suggestions?
