Hi guys What is the best way to seal MDF edges in preparation for staining. The MDF is oak faced but the Client wants the edges rounded over with a router then stained in with the top and then varnished/polished.
I would suggest actually using oak - but I bet the MDF has already been bought ? It is is going to be a pain to get the colour to match. I spent a lot of time and effort a few months back getting white pine to look like light oak. Would the customer accept a chamfered / beveled edge and you could put a banding on that way
If your clever, you can steam bend iron on edging roll. But, as Astra said, glue oak strip to mdf, then rout rounded edge, a lot easier,or get some half round oak beading & glue that on.
If he was clever, he would have router table, & saw bench & make his own beading,sadly not done much today.
The edge of the MDF has been built up to 55mm thick and I've never seen iron on edging that thick and furthermore she wanted it stained as apposed to lipped.
Here. http://www.woodveneeruk.co.uk/proddetail.php?prod=American-White-Oak-Iron-on-Edging-55mm-wide Great firm, don't use them much nowadays.
None in stock. Go easy on the OP! I see the finish requested quite a lot. Usually on the panelling around pub urinals ;-) Looks fine for what it is and seems hardwearing.
Made three 2.4m fluted planks this week, 75 mm wide with 5 flutes things haven't been that clenched since my last prostate exam
