Stanley fatmax tools.
Discussion in 'Tool Talk' started by plumber-boy, Nov 9, 2015.
  1. plumber-boy
    plumber-boy Well-Known Member
    I have started using a few of their power tools and must say they seem pretty good, I've had their multi tool a few yrs and its been a great tool.Does anyone else use them or do you think they are carp??
  2. DNR Plumbing
    DNR Plumbing Active Member
    Hand tools are fair diy quality at best and do not stand up to daily hammer
  3. chippie244
    chippie244 Super Member
    I had a fatmax tape once and I hated it, the return spring was so strong every time you retracted the tape it either cut you, gave you a blood blister or shot out of your hand like a psychotic yoyo.
    plumber-boy likes this.
  4. plumber-boy
    Your avatar still scares me chippie.:eek:
    KIAB and Tiny01 like this.
  5. chippie244
    I have a better one but can't get it on my laptop and can't be bothered to use the PC.
  6. plumber-boy
  7. chippie244
    Much better than that.
  8. joinerjohn1
    joinerjohn1 Screwfix Select
    I have two Fatmax spirit levels (6ft and 4 ft) A Fatmax framing hammer, a Fatmax claw hammer and a Fatmax 15ft tape measure. As Chippie says , forget the tape measure, the spring return seems to give it a life of it's own (and yes, it's bloody dangerous) :p:p:p:p:p
  9. chippie244
    It's not just me then :):)
  10. sospan
    sospan Screwfix Select
    Essentially FatMax tapes are like us start out sharp, then dull with age .... ;)
    Yep they are really vicious when new, I had mine 3 years now and still going good. The one thing it is really good for playing out quite a way without collapsing. I quite often have to work alone and the reach of the tape without kinking is very good.
    The rest of the products are a bit hit and miss, some good / some not worth the money. I couldn't find my slip joint pliers and had to go to our hosts as they were the only ones near me that had any - eye watering price, over engineered - £23. Tempted to keep them in a glass case on display
    http://www.screwfix.com/p/fatmax-12-300mm-groove-joint-plier/25268
  11. chippie244
    I gave mine to someone I didn't like.:D:D
  12. KIAB
    KIAB Super Member
    Got a 6' Fatmax pro box beam level,pretty decent kit.
  13. sospan
    Your mate who goes by his new name "stumpy" ;)
  14. metrokitchens
    metrokitchens Screwfix Select
    I find their hand tools good for the money.
    Just got a 18 volt combo drill with two 2 ampHr batteries for £70 from Argos sale. So far seems a decent bit of kit. Puts holes in brick for plugs easy enough and perfect with a hole saw.
    Will wait and see how long the batteries last before giving a 5* review.
  15. plumber-boy
    You gave it to Walt.
  16. chippie244
    What would Walt do with a tape measure, see how small his winky was?
  17. plumber-boy
    :p:p:p
  18. Phil the Paver
    Not before he changed the tape.
  19. plumber-boy
    :p:p:p hi Phil, how you doing mate.
  20. plumber-boy
    I bet the one on his head is bigger than the one in his trousers. 5iRKM5ReT.jpg
