Looking for some helpful advice / tips please - Replacing the stone tiled flooring in my kitchen and hall but don't want to lay new flooring in 2 cupboards (1 toilet & 1 large walk-in pantry. What is the best method for cutting a straight edge across the floor tile under the door and with what? So as not to see the join I was thinking of using the bottom of the door with a trim joining the Karndean to the original tile, plausible? Cheers Howzit
Thanks Sospan I get the timber straight edge as a guide, and running a angle grinder with a thin blade across,but how do you get a tidy job at the corners of the door posts?
I use a Mulitool / Multicut tool with a abrasive bit. Something like this. You could do the entire cut with this but it could be hard going http://www.screwfix.com/p/bosch-tile-grout-grinding-blade-85mm/6938k
Thanks for all your help Managed a decent job with a Erbaur tile cutting disc in an angle grinder I had about 15 mm depth, so managed to get the corners with the same tool
