Hi plumbers! Is it possible to fit Surrey flange on the side of the cylinder? Or should I use another flange?
yeah, I know there's lot more fun with Essex but thing is... I've ordered combi cylinder, 200l for hot water + 40l CW tank. Cylinder came with all needed threads. So I don't need to drill any other holes except overflow outlet and mains inlet into the tank. As it's combi cylinder there's no space on the top of the cylinder
To run a pump your going to need a header tank at least five times the size of the one you've got. You will run a 40ltr dry in about four mins or so.
