Swapping 12v axial fan for centrifugal
Discussion in 'Electricians' Talk' started by 14th edition, Dec 8, 2016.
  1. 14th edition
    14th edition Well-Known Member
    Customer had a bathroom renovated and fitters put in a timer axial fan, about a metre or so of ducting but this in a roof space with no access. Whatever its not extracting well and there is bad mould as a result. The ceiling is very high, in excess of 2.5metres and the transformer is mounted on the ceiling inside the bathroom. [No, no RCD on circuit]. Leaving the issue of no rcd to one side is there a 12v centrifugal fan that will run off the transformers timer?
    I spoke to Greenwood and they said all their 12v and need l and switch line and if you link them they will run until the light switch is turned off. i.e. they won't run as a standard fan off the transformer timer.
    Any ideas?
  2. CGN
    CGN Screwfix Select
    You could create an access hatch and fit in a 240v inline fan.
  3. 14th edition
    Thank you, but not in a million years!
