I have a boiler stove on the ground floor and pump and injector T on the first floor. The F&E is in the loft raised about 300mm above the rafters. The f&e fills up and overflows every few weeks. And one rad collects a lot of air. I'm thinking their might be a reversed flow around the injectorT! Will raising the f&e to higher level (thus increasing the head) cure the problem?
Ok I've raised it by 1.3m right up to the apex of the roof. I can't go any higher now unless I raise a section of the roofing. I'll report back in a few weeks and let you know how it goes.
Working a lot better now. Pump doesn't sound like a steam train. Though still some air collecting. Thanks for all the help.
