I HAVE A 12inch table saw and was wondering if I could put a 10 inch blade on it? Is there any issue at all with doing this? Thanks. Ed
One serious sawbench,sawbench was designed to be used a 12" blade. Freud blades are very good choice,only blades I use.
I can swap between 12" and 10" on my machine. But the riving knife is adjustable and the machine designed for both sizes. I can also add felder dado tooling as its designed for that also.
So long as you match the bore size there's no issue,just remember that it won't cut the same thickness of timber if you use a smaller blade.
