I took the dimensions for the height of the pulleys from the existing sashes. The groove between pulley stile and inner lining is because I am using this:- http://www.quantumprofilesystems.com/en/brands/qwood/sash-profiles/20mm-clip-in-staff-bead- Using their parting bead as well
I'm interested why you think the pullleys are high. Since you said I have had a look on t'internet and you're right - many of the illustrations show the pulleys a bit lower. I can't see why it makes much difference - why do you think it will make maintenance more difficult? I might change it on the next ones if there is a good reason. BTW, I have modified the traditional design - my weights "pockets" are actually the lower section of the inner lining - didn't want to have them on the running face of the pulley stile. Won't be quite as accessible, but how often do you have to re-cord.......
Its for maintenance in years to come. simply getting a hand tool in there to effect any works. The rounded rebates are nice but I use square cut pulleys for simpler replacements. If the pulleys are all metal it will be fine for a long time.
Cheers. Yes pulleys are these https://www.mightonproducts.com/brass-pvd-face-plate-2-brass-wheel-round-ends
I quote for a cord change, bog standard job, and all of a sudden the staff beads are rebated in and I can't get a replacement and where the hell are the pockets. You are fixing problems that don't exist again.
Looked up Accoya, there is an article that recommends PVA 4 http://www.constructionchemicals.co.uk/files/downloads/WPPVAD4.pdf http://www.constructionchemicals.co.uk/Water-Resistant-PVA-Joinery-Adhesive-D3.html may be worth having a look
Pockets are the bottom 500mm of the inner lining. Just didn't want the pockets on the face of the pulley lining to potentially interfere with sliding seals. I noticed several of the window suppliers at the renovation show at Harrogate I went to recently didn't have weight pockets on the pulley stile either. I expect for the same reason. I realise the design I am using isn't totally traditional, but as a certain London company has been kind enough to post their CAD drawings I thought I would basically copy them..... The staff beaf clips into a plastic insert that goes in the rebate. Easy to lever out for maintenance without damage.
I don't understand how you access your sash weights or what happens when the company supplying your staff bead goes bust and a chippie, not realising what he is dealing with and why would he, breaks one.
Sospan. That's interesting that they recommend their pva4. I have titebond III here which is also a high performance PVA but the only info I could find said it wasn't so good on accoya. Maybe I will have to do some unscientific tests because I would rather use PVA.
Chippie. The wagtail only needs to come down below the top of the weights to keep them separated. With the bottom section of the inner lining removed easy to get weights in and out. We are intending to hang on to this house hence not using the cheapest materials. If some chippie breaks the staff beads when I'm pushing up daisies I won't really be that bothered.
What I mean is you must now have a visible join on the inside of your window which will have to be broken any time you have to work on your sashes. Do you have to take your arcs off as well?
Yeah the pocket needs to be accessible, otherwise you have to do a lot more making good. new pulleys can sometimes have a sharp edge and will cut through cord.
I have tried PU a few times, whilst it works where the timber stays dry, I have seen it break down over a few years outside. Whether it is because I am near the sea, but prefer other adhesives for outside
Y arcs off. One screw and the bottom section of the lining will come away. I decided I would rather have the joint to be broken there than on a face with a sliding seal. Nice smooth pulleys. Best quality 7mm cord. I expect it will outlast me. I'm certainly hoping that once installed they won't be coming apart in a hurry.
