I've been trying for ages to get a proper tap connection for a mixer tap for a hose pipe can anyone pls help
It's not too hard, there are even kits which are designed to be as painless as possible. Google it to get an idea
Our host do a basic outside tap kit. http://www.screwfix.com/p/outside-t...nd Gardening&gclid=CLXu44nA1cwCFRSNGwod6K8Kug
Have you tired one like this. https://www.amazon.co.uk/Hozelock-2...&sr=8-3&keywords=mixer+tap+hosepipe+connector
SoulRasta, you can do this... Look into yer sink unit. Identify the 15mm copper pipe wot's feeding the cold to your kitchen tap (or the same pipe as it heads to your washing machine). Buy one of these: http://www.screwfix.com/p/self-cutting-tap-15mm-x/21250 Decide where best to fit it on that pipe where you have good access to it (the fitting itself can rotate so's the 'tap' part is where you want. Fit it. Screw a hose connector on t'end: http://www.screwfix.com/p/hozelock-brass-threaded-outdoor-tap-connector/95018 Every time you want to use yer 'ose, chust open your kitchen cupboard door.
SoulRasta, see your last photo - the one that shows the 'blue' W/M valve behind the black waste pipe? Well, anywhere on that copper pipe will do. If you follow the pipe down from that 'blue' valve, it 'tees' into a horizontal copper pipe. That short straight bit to the right of that tee looks accessible enough? Or, if you follow that pipe around, it bends - are there any sections on there you can get easy access to? Seriously - fitting one of these 'self-cutting' valves is a doddle - and you'll feel chuffed you've done it. Just turn off the mains stopcock first! (That baby in your 3rd photo.) Trying to connect a hose on to a tap spout is sooooo last decade...
Here's a thought, If you dont want to do it how about getting in someone who does it for a living? Think that there called plumbers, Im sure one of them could could just about manage it. Sorry i know sarcasm is the lowest form of wit, but this thread is doing my head in
I have tired every thing one thing ur not nice thought this was to ask questions not about being sarcastic
No worries. You'll only get moaned at if you get the answers and then don't act on them . Anyhoo, 'SoulRasta' is a cool name. So act it, man - do some plumbin'...
it was someone on here that moaned about it and the reason why I'm asking questions is am a woman not a guy and the name soulrasta I'm into ub40 bob marley
