Tiling over Lino Adhesive?
Discussion in 'Other Trades Talk' started by Shaz02, Apr 7, 2014.
  1. Shaz02
    Shaz02 New Member
    Hi guys,
    Got about 20sqm to tile - I have removed the old lino, however the majority of the adhesive has stayed on the deck.
    Its a concrete floor, and the adhesive is flat (Still sticky!) but not in lumps...
    Is it good to tile straight over this? Should it be sealed? or should I lay down some self leveller?
    All help would be appreciated.
  2. I would use a tile adhesive primer first before tiling
    Shaz02 likes this.
  3. Shaz02
    Shaz02 New Member
    Thanks for the reply! - Will have a look :)
  4. diymostthings
    diymostthings Well-Known Member
    I had a similar problem having removed some glued PVC tiles prior to laying ceramics. I found that a hot air blower softened the glue sufficiently for it to be scraped off cleanly from the concrete floor. However it took me roughly 20 mins to clear 1 square meter!
  5. metrokitchens
    metrokitchens Screwfix Select
    My tiler insists on taking it off. Usually with an angle grinder at a shallow angle. Does not take too long but it is messy. But he really is a fussy perfectionist who thinks the tiles should never ever never never come up again.
