TITAN 1010W SDS plus drill - wonky chuck
Discussion in 'Tool Talk' started by mozart, Jul 11, 2016.
  1. KIAB
    KIAB Super Member
    mozart likes this.
  2. philthespark
    philthespark Active Member
  3. KIAB
    KIAB Super Member
    Total rip off what Bosch,Makita charge for a 30gram tube of grease.
    Been using Castrol Moly Grease for years on my Bosch.
  4. mozart
    mozart Member
  5. philthespark
  6. mozart
    mozart Member
    Thanks for confirming and for the tip!
  7. KIAB
    KIAB Super Member
    Grease on sds bits tips,never done it in 30 years, the only grease I apply is when I remove the chuck from drill, just a spot there to lubricate hammer spindle (sliding action in the chuck).
    And occasionally grease to base of a sds chisel, & sometimes a bit.
    http://community.screwfix.com/threads/sds-drill-lube.8280/
  8. philthespark
    By tip I meant the end that goes into the drill,not cutting tip,sorry.I always tell people to put it on the end rather than just ramming it down the chuck,stops them putting too much in.
  9. Jitender
    Jitender Screwfix Select
    Thinking of replacing the lead or adding a connector. Very awkward sanding sanding wall and ceiling, dont know why they couldn't have put an extra meter or so of lead on it.
  10. KIAB
    KIAB Super Member
    I have cut off the pre mould plug on my 220v tools & fit 16A blug plugs, & have a selection of extension leads using the blue 16A 1.5mm arctic cable of various lengths 2.5mtrs, 5mtrs,10 mtrs & 20mtrs on a reel with the blue sockets & 3 pin plug other end, covers most my uses around the house,garden.
    And a couple of these made up come in handy for some smaller power tools & soldering irons.
    [​IMG]
    Jitender likes this.
  11. Jitender
    I've ordered a roll of H07RNF cable 2 core 1.0mm.
  12. Astramax
    Astramax Super Member
    Would an extension lead help?
    KIAB likes this.
  13. CGN
    CGN Screwfix Select
  14. Jitender
    I have an extension reel, but is very annoying when i have to lift it make more work and usually gets unplugged.
