Ihave just purchased the above saw and after adjusting fence and blade i need to go 1degree above zero to get correct end cut. Is there a way to adjust stops to align with this.
You should have some fixings on a guide bar? local off point type thing, slacken them off ever so slightly and give the saw a tap in the direction you need to go
Many Thanks Wiggy. Grub screw under base slots into grooves for 90 45 15 etc but not close enough to alter.Have now got the cut perfectly square.Kind Regards Hally
