Tiler requested i remove toilet for tiling which I did. Now that Ive refitted it, the plastic water inlet coming out of bottom of cistern doesn't reach the copper water pipe... What can I do?
Is there any give on the copper pipe? If not then fitting an isolation vale, if one isn't already fitted will do the job.
Or failing that for a quick diy fix cut the pipe and put a flexi tap conector on it. But make sure the water is off first.
Buy a service valve (tap connector with isolation valve) instead, this will do both jobs in one and will give you that extra bit.
