TRV on Bathroom Towel rail
Discussion in 'Plumbers' Talk' started by Julian1, Feb 7, 2007.
  1. Julian1
    Julian1 New Member
    Gents,
    Can you advise if I should or should not fit a TRV on the bathroom towel rail. Also, am I right in saying that they must be fitted to the flow pipe.
    Many thanks for your help
  2. Mad Print
    Mad Print New Member
    Hi Julian,
    I'm NOT a plumber, but I have recently fitted a towel rail radiator without any problems. Mine's fitted with a TRV, some people don't use them so the rail's heated all the time the CH is on (it will also act as a bypass on an otherwise all TRV system). Most modern TRVs are bi-directional, so it shouldn't matter whether they're fitted on the feed or return.
    One extra worth considering is an electric immersion heater type thingy for it - you'll still have warm towels in the summer when the CH is switched off.
  3. Stuart W
    Stuart W Member
    Hi Julian and Mad
    I'm NOT a plumber either.
    I have had fitted recently a chromed towel warmer without TRV. I worried a little about this but unduly. Firstly because it is chromed then it radiates a lot less heat than, say, a radiator - it is still hot a long time after the heating has gone off. Secondly I always cover it with towels so it warms the towels and not the room - the towels insulate it.
    I suppose the thing to keep in mind is that it is designed as a towel warmer and not a radiator.
    BTW I also have a radiator in the bathroom - this HAS got a TRV.
  4. if you wanna fit a trv to a towel rad then go ahead but personally I never do ....there's a risk of the towel covering the sensor and stopping it from working properly
