UFH Schematic Help
Discussion in 'Plumbers' Talk' started by ddac84, Sep 12, 2017.
  1. ddac84
    ddac84 New Member
    Hi people..
    I really hope someone can help me out here.
    I am removing pretty much the entire heating and hot water system in my house and putting in UFH.
    Now I cannot make heads of tails of how they have the current system installed.
    But basically I need a plan on how to plumb in what is essentially a completely new system...
    I have added a pic of the new system but I cannot figure out how to plumb it all in. The current system is a total mess and is going.
    So basically I need a plan on how to connect everything up. but I also need at add a pump for the hot water, the UFH manifolds both have their own pumps.
    If anyone could be amazing and help me out I will be forever grateful! Will happily send £50 via paypal. I have 2 wiring centers for the UFH and hw etc and know how to wire them in ive done it before, but the placement of the valves is also over my head. so if you could include the valves in the plan that would be awesome...
  2. Dave does Gas
    Dave does Gas Well-Known Member
    Im not being rude here but I feel you need to get a professional in to do this for you if your asking advice on the basics.
    The UHF companys will design a system for you if you send in room dimentions and layouts etc. but you need to understand the basic design of an S Plan or Y plan system, the configuration of the cold feed and open vent, the list goes on.
    Please call in a pro.
    leesparkykent likes this.
  3. ddac84
    ddac84 New Member
    I've got the design, laid it in my previous house. but that was a simple job cos I didn't change the hot water cylinder etc. The reason its all being changed here is because its all a huge mess.
    Its not rocket science if you have a diagram - the diagram might be rocket science but fitting it isn't.. No offence to any plumbers.
  4. ddac84
    ddac84 New Member
    This is what I think it should be like, but im not 100% sure. Ive left out the vent pipes and the mains water feed in. and hw out of the HWC
  5. ddac84
    ddac84 New Member
    Does this look right?
  6. kiaora
    kiaora Active Member
    Hi,
    It's not quite right,
    From the boiler flow, it's, vent, cold feed, ( within 150mm),
    Then pump, bypass, then a common header to supply the 3 zone valves,
    The way you have it, it wouldn't work, the uf curcuit neens a pumped supply, the pump on the uf, only circulates round the zone
    Hope that helps
    Regards
    Peter
    ddac84 likes this.
  7. ddac84
    ddac84 New Member
    Does it need a bypass valve if its connected like this? Thanks for your help :)
  8. Pollowick
    Pollowick Well-Known Member
    On my system here, the cold feed from the header tank and the overflow share a 22mm pipe most of the way and only split a little before the header tank.
    And the valves on the manifolds often have Hot Feed In & Cool Out on te system side, then two connections on the UFH side.
  9. kiaora
    Hi
    It's normal practice to fit a bypas, often the pump is controlled by the boiler, so it can overrun to disapate the latent heat from the boiler, and also for when the stats close the zones on hot water,
    Regards
    Peter
    Note, don't forger the magnetic cleaner, and dosing pot, on the return to the boiler,,and any thumb vents at high points that may form air locks.
    ddac84 likes this.
  10. ddac84
    ddac84 New Member
    Thanks Peter!
    Have a mag cleaner and dosing pot already, (1 of the few things that aren't being changed haha)
  11. kiaora
    Hi
    Schematicly it looks fine,
    In real life, it's best to make it so air naturally rises to the vent pipe, from the boiler, and an auto bypass helps the pump, do its job,
    I.e., all the pump effort is round the circuits except when some zones are closed, and then the auto bypass will do its job, and open and keep the pump resistance steady.
    Regards
    Peter
  12. kiaora
    Btw
    How do you do the drawing?
