Hi guys sorry if this is in the wrong section. I bought a upvc door and made the school boy error with sizes. The door is 100mm taller than it needs to be. I've been told that the manufacturers can't re size that actual door/frame it would have to be a new door is that correct? Also when I've tried to sell the door a chap came and looked at, he said it wasn't usual because the bottom corners of the frame weren't sealed this would let water under the door is that correct? I added pics so you can see
nothing wrong with that door. the vertical piece is wider than the horizontal because ( my guess) is that the hinges are there. So you can open the door fully when fitted. If they didn't do that, hinges would interfere with internal plaster. whoever came didn't want the door keep advertising it, you'll sell it but I doubt for very much sadly
There is something about that, that's not right for a new frame, its been cut badly and as you say full of silicon. Why??
I'll tell you why. Firstly, some fool has bodge-cut that thinking that it will drain out. Where will it drain to? The cavity. Ooops. So with a second thought, the fool seals up the cavity end of the cut and just leaves a front vent which he thinks can run out on to the sill. He's wrong on all counts.
So am I right then that the frame has been made wrong, I don't want to start disagreements but I'm not sure it came from the manufacturers like that so I thought I looked odd but just took as it's right
Well that's why I have queried it as any water would sit underneath the frame I'm going to email the manufacturer and see what they say
Not familiar with UPVC windows. But ordered windows here for house and drainage could be concealed or face. As we have terracotta tile cills there was no need for a cill or sub cill so just select 'face drainage'. Which has slots in the front of the frame.
If you asked for no cill then that door is totally wrong, it should be a low threshold frame which is only about 15mm high. Something along these lines.
They gave me choice of full threshold or low disabled access threshold. So that full apparently the top isn't like that either it's fully sealed
I ordered a standard threshold though so they have admitted something is wrong and it looks untidy in my opinion
