I have re oiled my oak worktops after sanding them down and it seems a bit sticky, why is this ? I used Ronseal danish oil and give it all 3 coats,rubbing well in and removing excess, leaving each coat over night to dry, its been weeks now and some parts are still tacky, it was all sanded down to bare oak ? thanks
dvddvd, A possible reason: Did you do your best to extract any previous treatments by using a solvent in combination with rags and steel wool? Residues of the previous treatment may be affecting the drying of your new treatment. White spirit may be good enough for some treatments but a solvent such as acetone may be required to achieve a satisfactory standard of cleaning out, especially if wax is present. Sanding alone will not remove the residue of the old treatment. It may be best to start again and thoroughly prepare the worktops as if from scratch. Wear a good quality respirator when using acetone, it is a very strong solvent. And remember to do a test area where it is least noticeable before embarking on the whole of the worktops.
PS You can experience the same problem with very greasy or oily wood, same treatment. Scrub the surface with the solvent and wire wool then wash with the same solvent. Don't let acetone come into contact with any other surface.
When I first did the worktop, I rubbed the oil in and removed excess oil. I have seen worktops done before with danish oil and they seem to have a very satin /flat finish, but when I did mine it just looked like it had been varnished with a normal varnish, it was quite yellowy and had a high build up on it ?
Doesnt sound like Danish oil to me. Danish usually starts to soak in quite quickly and when you wipe the excess of it will start to look flat fairly soon.
