Hi what size supply do velux window openers normally require ? 3 amp supply via a high level fcu high level if i.r remote used . If wall switch high level fcu and 3 core down to mid position switch im guessing ?
The motors on automatic openers only require a 3A supply. The actuator switch needs to be a mid-position off with press up for open and press down for close (centre off retractive push switch).
Yes it is very foreign style lol a graphic designer did it from Greece . they did some other work and sent me that for free lol
