Help! I am installing 3 tall cabinets, housing a built-in fridge/freezer/oven respectively. I want the top of the cabinets to be as close to the ceiling as possible (I can get to within 10/15mm using standard units). Is a 10mm gap at the top sufficient for ventilation purposes? Thanks folks' Ian
Hi Ian, You will need to read the appliance manufacturers information. They will tell you the flow you need. I would recommend a couple of grills in the plinth. I had a similar situation where I put in some grills. I also put a vent onto a wall which the units came to. Good luck
