any advice on a walk in shower or wet room,for example the best kit to buy etc there will be 2 solid walls but they would have to be dry lined with plaster boards or hardi boards to straighten the walls up and a glass panel on the side,the floor is constructed of 9x2 joists and 38mm floorboards so whats the best base and tanking to use or can i use sbr/cement as a tanking and the shower area and floor is to be tiled,thanks
have a look at the impey wet room range, lots of places stock it, its a good system and is pretty easy to install, i think even topps tiles now stock it, theres loads of vids on youtube about installing there systems, impey have good back up and technical advice
