Hi All, I have got some electric chases to run in a wall and was wondering about the use of expanding foam. This has probably been queried before but I saw one in Maplin (http://www.maplin.co.uk/p/everbuild-fix-and-fill-expanding-foam-filler-750ml-a22rg) which seems to indicate it can be used. I admit there is a large price difference but was wondering if any expanding foam could be used because it is made differently now? Thanks, Kevin
IMO, if you are plastering over then don't use exp foam. It will be more trouble than it's worth. Use plaster bonding coat to almost fill the chase and then hardwall skim to finish.
Thanks Bazza, I was toying with the idea of filling, cutting down to level with plaster then painting.
Bonding plaster then easifill. The beauty with easifill is that you can sand it down to the existing plaster and will be invisible if you've done it right Btw, if its an old property with no cavity wall, then use sand/cement render instead of bonding...
Yeah as cgn says as bonding coat will absorb moisture. One thing a lot of people have said (although it's handy) is that one coat stuff is carp. I find the dry wall adhesive good for putting galavanised boxes in. Goes off in an hour and rock solid
All the chase I have ever done have been capped over with metal capping. Used one coat plaster to set the channels in as find it is more denser, but never able to achieve good finish on its own, so tend to use it to fill deep holes or setting in back boxes. Then go over with filler.
Always had trouble trying to feather in the edges using finishing plaster. Filler is easier to sand. Does take time but not professional. Wall are painted so have to be perfect. Did use undercoat plaster for one job see 'Nest project'.
I'd also say, don't use bonding on the internal face of an external wall. if there's any moisture in the wall the bonding pulls it through, I'd opt for sand and cement here then skim.
I've used Thistle multli finish as a undercoat & skim coat for filling a lot of chases over the years.
Thanks all for the help, I do not know if this should be under a new thread or not but as part of this work I am also planning to install an external socket with the RCD built in. Because I am extending the ring main (hence the original post) I am assuming I can spur off one of the sockets I am putting in. My predicament is do I put in an FCU and then spur off that or do I just spur of the socket? Thanks.
And no need for an RCD socket, as if you're socket circuit isn't currently RCD protected, as your altering it, you should be providing RCD protection.
