Hello, I am currently looking to set up a washing line connected from the side of my garage to the side of my house. I have looked into it a bit and i think these might work - http://www.screwfix.com/c/screws-na...managedredirect-_-screwsfixings-_-throughbolt and https://www.steelgear.co.uk/product/eyenuts/stainless-steel-eyenut/size-m10 now my question is if i were to use thread-lock would it stop the eye nut from rotating? or would i have to get a bit more drastic and use resin or a PTFE tape? Also if you could tell me, are the items i have linked worth using or is there a simpler way around this. Kind Regards
Garage pre-fab or solid block. If pre fab,I have use simple fencing straining bolts with a double nut, they are around 150mm in length so easy to go completely through 100mm block wall. Will need large flat washers either side, I used large flat washer & then a square plate washer either side of wall. https://www.diy.com/departments/verve-steel-eye-bolts-pack-of-4/314513_BQ.prd Can buy above singlely. House end just use Masonry Anchor Eye M6.
Hi KIAB, Its solid block on the garage. Also i do not know what a straining bolt looks like. Do you know of any websites that sell them?
