I am having a downpipe fitted for a water butt but realise there is no drain in the vicinity. Will this work?
I suppose the same as if the butt wasn't there. Just fit an overflow pipe to the butt draining away on the ground, or if possible, a near by flower bed.
Oh dear. I was hoping that there would be some sort of device that might be put into the downpipe to divert water from a full butt back into the gutter (which drains into my neighbour's drive)
A little lateral thinking ... Fit a ballcock in the water butt and feed that using say 22mm pipe from the gutter (with a filter). You will need to find a way to convert from the gutter to 22mm but it must be do-able. Water will flow down the pipe until the butt is full and then as the ballcock turns off no more will flow down.
This is all you need; http://www.screwfix.com/p/rainwater...tracking url&gclid=COyPlIO_-84CFdXGGwodYEQJbw Regards, Cando
Don't think it will as the feed through is open ... I read it as though there is a downpipe there already which drains onto the neighbouring drive. The OP is having a second downpipe fitted specifically to fill the water but and does not want surplus flowing onto his garden.
That is correct, Pollowick. These houses were original built as large detached dwellings but this was during a recession and because they weren't selling the LA gave permission for amended plans, changing them to two semi-detached. It sort of works but this is the reason for the odd drainage - all the run-off from the roof goes to a gutter leading to a drain on my neighbour's side. Thanks for all the advice chaps. All ideas welcome.
