Water Hammer Aresstor
Discussion in 'Plumbers' Talk' started by James1gbu, Sep 12, 2017.
  1. James1gbu
    James1gbu New Member
    I have a problem in a flat im working in where there is quite a loud water hammer.
    It only happens when the kitchen tap(lever shut off) is closed firmly.
    The tap has been changed but was doing it with the old and new one (both lever taps)
    The noise seems to come from where the incoming main is which is at the other side of the flat and no noise is heard in the kitchen where the tap that is causing it is.
    I have recently changed the PRV as the old one was leaking and i thought this was the culprit as the gauge would flick between 2.5 to 3 bar when the tap was turned off suddenly.
    Now im going to fit an arrestor but wondering do i fit it where the cause seems to be i.e the kitchen where the tap connects to the pipes or do it fit it where the noise is heard next to the PRV incoming main?
  2. KIAB
    KIAB Well-Known Member
  3. James1gbu
    Thanks for the reply
    Yes that is possible but when i turn the stop cock off it doesn't have a 'feel' to it like there's a problem with the washer or jumper, its fairly easy to turn off and stops the water right away and you can feel the slight resistence there as if its pressing against the washer.
    I will look into that though but a bit more tricky as its in a block of flats and would need the housing management to turn the building off to check it out.
