wc with defective outlet
Discussion in 'Plumbers' Talk' started by saba, Aug 30, 2015.
  1. saba
    saba New Member
    I have a new wc with an outlet that is not symmetrical - manufactured incorrectly. Wondering what I can do to prevent leakage as outlet pipe is circular so not exact fit. I do not want to throw it away so any suggestions welcome?!!!
  2. miss pickle
    miss pickle Well-Known Member
    Herb garden? :) Maybe? :oops:
  3. saba
    saba New Member
    yes I had thought about that too
  4. miss pickle
    Could go for the whole suite :D
  5. miss pickle
    CPM is a man of few words saba :rolleyes: unlike moi.
    But what he does say makes sense :D unlike moi :oops:
    Have a nice bank holiday CPM :)
  6. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    In what way 'not symmetrical'?
    There was a thread on here not long ago with a couple of solutions.
    Mr. HandyAndy - Really
  7. nigel willson
    nigel willson Screwfix Select
    Not symmetrical , that's y we use flexible couplers .
  8. saba
    saba New Member
    yes I have got to that conclusion - flexible connector/ coupler but have to find the right size -the external dimension varies between 95-105mm so the connectors at Toolstation are too big
  9. saba
    saba New Member
    and screw fix too small
  10. miss pickle
    Can't you get the bigger one and then use a reducer to reduce down to 95mm?
  11. saba
    saba New Member
    could try just looks a bit too big
  12. miss pickle
    Have you got a plumbers merchants near you? If you just go in and tell them what size you need to go from and get down to they will give you the correct fittings :)
  13. miss pickle
    Or they will order it in :)
  14. saba
    saba New Member
    thanks
  15. miss pickle
