I'm about to get my bathroom converted to a wetroom. The Bath is going (Used it 5 times in 20 years!!) and being replaced with a walk in open plan shower. I will be using No More Ply boards screwed to the floorboards, then sealed with a membrane from RIW (Tilesafe) So far so good. The shower glass I have ordered is a substatial 10mm thick from Victoria Plum (V10 range 1150mm) On the bottom I noticed what appeard to be fixing plates. I queried this and got the instructions through. Basically to fix, you have to drill through on the shower side and screw down to support and fix. The last thing I expected to see or hear is that. Spend a fortune to waterproof, then drill a hile in the most vulnerable location. I was also curious about fixing the WC as well, since the screws would also penetrate the membrane. OK... You might think its not in a wetzone, so wont matter... but with 3 boys in the house... hmm.. lol Anyway... Back to the glass. Does this sound right? I tried (without any joy) to get some sense out of Victoria Plum, but their bottom line was buy it or dont.. ie we dont care and dont know the answer. (I was told.... just put some silicon on the hole before you screw down.) I really cant see screwing down where water is going to be running down a glass screen and probably the wettest place in the room, is going to work! Can anyone advise on this please? It must be common... surely? Oh... And the manual said to silicon only on the non shower side!!!! Sounds a bit strange to me! Ive attached the manual they sent me
Guv, I'm sure you'll get some good advice coming along soon. As for the last point - silicone on the non-shower side - that caught me as being strange the first time I came across it when fitting my own cubicle a few years back. But it does make sense - if you seal along inside joints, any water that gets past that seal anywhere will then have no option but to end up outside - 'cos it can't get back in! By sealing the outside, any water that tries to get through is stopped from getting outside - so it stays in... Logical when you think about it I think.
That would make sense fitting a cubical enclosure... but this is a single sheet of glass and a wet room.... its allowed to get wet! But keeping it inside the shower screen water will drain away. You might be right in concept.... but I don't get it!
Guv, just because it's a wet room doesn't mean you have to get everywhere wet, surely you don't want what ever going to be on the outside of the glass getting soaking wet do you !! As for screwing through your flooring, I can see your point to a degree, but if you seal it properly it should stay waterproof, or maybe you could just stick the bracket to the floor as opposed to screwing it.
Ah! I see, Guv. In a wet room case, it's not really important how well you seal the actual frame to the walls or to itself, as any water getting through will, as you say, end up draining away in to the central drain anyways . I was referring to installing shower cubicles in general, and I assume that the instructions you are reading apply to 'general' situations where you don't want water getting past seals and joints. In which case what I said above applies . Anyways, there's silicone and there's silicone - many different qualities and strengths out there. I did look this up a goodly while back, and I think what you would want - should you wish to avoid screws - is 'neutral-cure', 'low modulus' stuff. Very tough, great adhesive properties, won't let you down. There are many other products out there too, such as the 'Stixall' type stuff I've been using recently - sets to a tough rubbery finish, superb adhesion, very strong. Your shower screen frame has a flat flange at the bottom so a reasonable contact area? Once that's bedded down, it ain't going to move. (Er, provided your floor covering isn't going to either...) Some research required, but there is no doubt in my mind you can 'stick' these things down should you wish to.
Phil... of course I don't want to flood the room.. which is why I'm asking why you wouldn't apply silicon to the shower side of the glass panel. Not only stops water escaping but adds extra strength to the panel in stopping movement. A win win I would have thought!
Devils A.... The only floor drainage is in the shower itself. Though being open, I'm not expecting to get much water on the non shower side. Glueing the fixing is certainly an option and one I have considered. And yes... my thought also about silicon helping to fix in place. Can anyone recommend a high quality silicon that will be best for that purpose?
The shower sealing issue - is the silicone the only thing to fix the glass panel to the walls as well? Anyways, which side to sili? Ok, the recommendation I read in my last set on instructions was to seal the outside only. If you seal the inside, and a wee leak/break occurs half-way up the panel, where will the water then go? Once past the inside seal, it will end up outside 'cos it runs down hidden inside that corner-jointing or wall-mounting strip and can not get back in - so it goes ootside. I recall it made sense when I read it...
How can a leak occur? its a 10mm thick solid peice of glass? That is literally all the panel is... a huge pane of glass. Nothing can get inside.... But it could get under it .... unless its sealed!! Its fixed to the wall with 2 brackets from the panel to the wall the shower sits on. Ive also added strength by using to small (250mm) side panels. Ive uploaded the fitting instructions in the first post, which should make things a bit clearer. (Sorry if I confused!) To help.... this is the item itself... http://www.victoriaplumb.com/Shower...-Luxury-Minimalist-Glass-Panel-1150_1749.html
here's an alternative view I wouldn't seal under the glass at all - when you shower using water at 35 - 45 degree there'll be a temperature differential of around 15 to 25 degrees between the faces of the glass - you WILL get condensation building up on the non shower side if you seal the base of the glass the route back to the drain for the condensate will be blocked it's a wet room, it's designed to get wet - assuming that the route to the drain isn't uphill it'll all drain away whatever gets wet
That's one way of looking at it.... though not silicon in at all will definitely mean the floor on the wrong side of that panel would be saturated. I will have underfloor heating so small amounts of water would soon be dealt with. Would you drill holes in the newly laid tiles and break the membrane seal to fix this glass panel?
having just spent a lot of time making it all wet proof it does defy logic to penetrate it - but what other options are there drill the holes, fully fill them with a good quality polysulphide mastic, coat the base of the bracket, filling any voids under it if there are any - it'll be watertight for sure but as you've got UFH be sure your fixings won't hit the loops/wiring below
Indeed... The danger of the UFH is another added concern! And of course the panel will be fixed on the inside of the edge of the former!!!
Ah - sorry, Guv, I misunderstood. I'd assumed a glass panel in an ali frame. (Mind you, with return panels you will have ali corner pieces...) Do not misunderestimate (I had to...) the strength of current sealants - they would undoubtedly hold the bottom of that panel securely in place, but would likely require a bead on both sides (as well as underneath). And that brings us to the main problem - cosmetic. It would almost certainly detract from the overall appearance of that rather nifty screen. So, I'm pretty sure that what I would do in this case is drill, plug and screw. Sealing well as Sean says, and using SS fittings. The good news is that there will be no bending force on them screws - it'll be almost purely shear. So you don't have to go deep into the floor, in fact in theory no deeper than the tile thickness. For the wee size of these brackets where they touch the floor, bed them down in the most sooper-dooper sili you can find. Don't worry about any water that gets under that panel - that should be taken care of by the slope you've built in to the floor. If you do decide to run a bead along there on the inside, you will see it - so might as well go the whole hog in that case and bead the outside too - for strength. And you can then leave out the brackets altogether.
the instructions say something daft like - seal the outside of the glass, depending on customers choice which usually means, our design department didn't have time to create an effective base fixing, so do whatever you think is best
The one I saw on display in a shop in Thurrock sat on a seal which I'm assuming was glued down and then both sides of the glass siliconed. It did feel solid I must admit.... I just feel uncomfortable having read the instructions but don't want to drill either!!!
I think I'd be happy to do away with those fixings - but only if there was a decent rigid fixing at the top you'd need to sit the glazing on a few mm of mastic, or some silicone that's specified for structural glazing (so not the stuff you get from Poundland) - raise the glazing up (maybe on a couple of tile spacers) while the glue/sealant/mastic is curing - make sure you leave it long enough to fully cure - then remove the spacers and trim the excess you'll then have a couple of mm of cushioned seal under the glass that'll have just a little bit of give in it
Im not 100% sure I'm following you Sean. I understand why its good to have the glass sitting on the mastic/silicon but not how you'd get it there if the glass is fitted. I follow the logic of the spacers... but just to clarify... are you saying mask up the tile area and glass, then mastic around and try to ensure it gets under the glass in a uniform amount, then cut all away... re do the but that was raised, then silicon around on both sides to give it full strength. (I cant visualise what you mean if its not that!!) In doing away completely with the bottom fixture, I'd end up with 2 holes in the glass, so I'm thinking I probably dont have an option but to use and glue instead of screwing.
Gluing only the two brackets might be chancing your arm. What is the worst that could happen in that shower? Someone slips and falls against the glass. It needs to be prevented from slipping away at the bottom - the glass itself won't (shouldn't) break, but you don't want it detaching at the floor and sliding away... So, a couple of short studs/bolts/screws fixed firmly in the bottom bracket and sitting in a shallow hole drilled no deeper than the tile thickness (10mm-ish?) A nice bit of clearance in that hole ( 1 to 2mm) around the chosen bolt, and then hole filled with the best stuff you can find and the glass lowered in place. Smooth around the bottom of the brackets, and... Hopefully.
Surely a hole drilled would need to be able to take a thead to screw it down. Or did you mean glue in the bolt into the hole?
