Looking for the daily use advantages / Disadvantages aswell as from the installing / maintenance side of things
Hi These have to be your last option, For:- - ideal for basement conversions - cheap alternative to drain modifications - easy to install anywhere - pumped to vertical discharge Against:- - noisy - high maintenance - if it blocks, poo comes out of every plug hole - poor life expectancy - easy way out - asking for trouble - renowned to block with over flow pipe use - no one want to clean them they are filth
the advantages are, you can have a toilet almost anywhere, saniflo have their dedicated team who will sort out any problems in the in guarantee period, they will come to your house and fix it providing its not because somebodies stuck a toy/paper cup or any other forbidden fruit down there, the disadvantage is, after the guarrantee period if it goes wrong its a dirty job and don't call me
G&W are you a plumber? where theres muck there's brass, when you signed the pledge shirley someone said " hey lad its not all pop and crisp being a plumber tha knows" or did you no have a mentor?
nay nay nay and thrice nay KIAB, when i was born we had middins, they were a hole in the ground where you did the business and the council emptied then every month, the lads doing that job would have never have dreamed about a little box doing their job,
I am plumber, heating, gas engineer and a good one, That means you won't want to pay me what I want to so much as look at a saniflow, An invention for lazy plumbers who want cash & dash, name me one plumber that would have one in their home????
Cheers as always guys & gals, Much appreciated It was out of curiosity more than anything & may also help others down the pipeline
http://www.diyfaq.org.uk/humour.html http://www.homeownershub.com/uk-diy/saniflo-876478-.htm https://groups.google.com/d/msg/uk.d-i-y/7xLYDWxZIg4/MmhtFHtfqV8J https://groups.google.com/d/msg/uk.d-i-y/p7WMjs3BmqM/UMEM6v9n-t4J Etc.
Only time I would even consider using a **** shredder would perhaps be to service a shower cubical or basin that had an impossible run. I was told the concept is French, just another way to get back at us for Agincourt!
