What is the best way to stick this stuff to my wall where I can't reliably screw? I want a proper tight bond, without melting the polystyrene. It's only for one small piece around my window, where I can't screw half of it because of the lintel placement. The Knauf guidance recommends their direct bond plasterboard adhesive to dot-dab, but I need to keep things as thin as possible (it's 27mm xps board, and I need it to rest above the window and not hang down below the window frame) cheers whitling2k
And a shame our host don't stock it,Wickes do, & even the Siroflex gun grade equivalent in TS is same price as Wickes.
Another brand is instastik which they do http://www.screwfix.com/p/dow-insta-stik-expanding-foam-grab-adhesive-gun-grade-750ml/72793
