I pre painted my pressure treated fence before I put it up about a month ago. It has two coats of Demi Dekk and looked great. Now it is covered on both sides the complete length of the fence in small white speks. It's not paint as my neighbors have nothing white that's been painted. Anyone seen this before and know what it is. Is it something inside the wood that's causing it? thanks for any replies.
Don't know what other people do, but I usually cut the picture, then paste into word then cut and paste into the message, seems to work, otherwise the picture is too big to upload.
If they're new fences could be the green preservative pressure treated which is having an effect with the paint. forgotten the term now tannalith?
Thanks Jit, that name I couldn't remember, need photo's to confirm, but the white specks I supect are saltings, sometimes you also get green specks, which I presume is copper salts, you get them on the surface of a boards,treated with Tannalith & Tannalith E, quite normal, can brush off, will disappear after some weathering of the boards.
Here is a cropped picture. Tried to brush of but just spreads as you can see on the last board to the right. Will it come back after another coat do you think.
Does it brush off, the way it's on the crossrail as vertical lines, don't look like salt deposits, they are usually random specks, this is on the surface of the brown finish, it hasn't come up from underneath the finish.
Was the tanalized timber newly treated or has it been around for a while as it is recommended the treated timber is left to weather for 6 months prior to any decorative finish being applied.
Very comparable price to other opaque wood finishes Jit such as Bedec Barn Paint, Sadolin Superdec, Dulux Opaque Wood Finish etc!
It was newly treated, as in, sitting about four weeks in my garage before being Painted. I didn't know it had to weather for six months.
Application remarks: Coating on fire protected cladding may cause salt precipitation/flaking. Doesn't mention anything about using it on pressure treated timber. Maybe an undercoat should have been used.
Yes it is but I got a good deal on a few 10L tubs. It's usually £150 a tub. It has a life cycle of upto 12 years according to the manufacturer.
This what you see with salting on pressure treated timber, can be just a few specks or sometimes a heavy covering.
No chance of that, I get on really well with my neighbors, and the photo is from my side, and it runs all the way up the fence on both sides. 22 metre.
It's not that. If anything it looks like a segull has had diarrhoea The speks are flat and not bumpy or raised like the picture.
