Hi, Im sprucing the kitchen and looking for some black finish shiny plastic I could buy to form a new window sill over existing sill. Also same material for some other uses to match worktops. Does anyone know what I could use and needs to be about 200mm wide by about 10-15mm thick. Ideally in length then I should be ok to cut lengths required myself (but not the width which is why I mentioned 200mm). Prefer a solid material self coloured black as dogs tolerant etc. Thanks
If you google 'upvc facia board' there's a big choice out there (or also know as capping) Not sure about shiny though but black is definitely available Only problem with this upvc stuff when used as sills it can scratch pretty easily and then it looks a mess Often with upvc window installs people go for timber / mdf sills as they just look better and can be painted during their lifetime Can you simply paint a timber sill with high gloss black - or have it sprayed Also look at 'Duropal' They do a massive range of wall cladding boards and splash backs that may be suitable. Not sure regarding a trim for front edge though ? Good luck
