A few bricks would give you a bit of lift. It's good to have a bit of air circulating underneath too as it helps keeps the damp down. Looking good.
I'll second that, you definitely need to get some air underneath, for a small amount of time, you will save a lot of hassle later.
You could cover the exterior walls with charred wood cladding. It`s a longevity method and weatherproof: it has been used in Japan for a long time where climate conditions range from semi-tropical to northern. You can find it here: https://degmeda.eu/
