Zanussi hob wiring"
Discussion in 'Electricians' Talk' started by Merman, Feb 1, 2015.
  1. Merman
    Merman New Member
    Wiring up my hob & it requires a loop to be connected between two terminals on the live wire.
    There is not enough room to fit both live & loop wires in the terminal- I used 6mm heat flex as specified.
    How would you connect this?
    Thanks for help.
  2. eric the fish
    eric the fish Member
    Is it a new hob? If so then look for copper "horseshoes" that may be in slots close to the terminals ready to be used as required. Good luck
    Merman likes this.
  3. seneca
    seneca Screwfix Select
    If the connecting plates are missing I use a strand of 2.5mm, no need to insulate if it's in the connection enclosure and between 2 adjacent terminals.
    Merman likes this.
  4. Merman
    Merman New Member
    Thanks for help guys.
    I had another look & found the copper connector plate so all makes sense now.
    Cheers
    Hugh O’ Leary likes this.
  5. Hugh O’ Leary
    Hugh O’ Leary New Member
    Hi Merman. I am having the same issues. I also have a copper horseshoe. How do you use it ? Sorry very new to electrics !
  6. Hugh O’ Leary
    my question is how do you use the copper horseshoe ‘man’. Didn’t think the question was that complicated.
  7. terrymac
    terrymac Screwfix Select
    The horse shoe is used to link two terminals, making them one.
    Ignore the " troll" who posted earlier Hugh.
  8. Hugh O’ Leary
    Thanks Terry, will try that tomorrow. Thanks again.
  9. terrymac
    Post pics of terminal block and wiring instructions that came with the hob if your unsure.
  10. Hugh O’ Leary
    Will do Terry. There were no instructions about the copper horseshoe. I just attached the live wire to one of the two live terminals but then noticed that only 2 of the 4 jobs were working which made me realise that I should be connecting to the second live terminal as well. Will post pics tomorrow. Have to turn off the power and have no natural light now.
  11. terrymac
    Ok. You should have got at the very least a wiring diagram and installation booklet/ leaflet. Is the hob brand new ?
  12. Hugh O’ Leary
    Yes I have a diagra m but it’s on the back of the hob and the hob is in place at the moment. Yes brand new, electrical shop wouldn’t provide installation service due to covid
    terrymac likes this.
  13. Hugh O’ Leary
    All sorted Terry, figured out the copper shoe and all 4 hobs now working. Just secured both terminals with the screws.
  14. terrymac
    Happy cooking !!!!
  15. Bazza
    Bazza Screwfix Select
    Hugh, I hate to be a critic, but you should have the copper cable wound the other way round the screw. You have both of them wound anti clockwise so that when you tighten the screw it tends to try and push the wire off the screw. If you wind it the other way, clockwise, the screw will pull the conductor tighter and further under the screw, making better contact.
    its a high current connection and it needs to be done properly, or you'll have problems later on.
  16. Hugh O’ Leary
    Hi Bazza, thanks for the tip. I had not idea but that makes perfect sense to me. Will get on that. Thanks again
  17. Bob Lyman
    Bob Lyman New Member
    Thanks guys I am installing the same hub, this discussion has really helped.
  18. nigel willson
    nigel willson Screwfix Select
    If you had read the instructions, you would have been aware. Nextime ah
  19. TomAXIS
    TomAXIS New Member
    Hi there, where did you find the copper link?? Thanks
  20. Bazza
    They are usually tucked inside the connector block. Often edge on in a slot.
    As me times they are already in place.
