Must Have Tools
Discussion in 'Plumbers' Talk' started by ceekay, Dec 20, 2010.
  1. ceekay
    ceekay New Member
    What are your must have tools the ones which you could not live without...
  2. P_Terry
    P_Terry New Member
    well, I would have to say I love my SeeSnake Micro inspection camera - I bought it for a one-off cabling job after trying for 3 hours to fish a cable with a coat hanger from behind some plasterboard and I've since found 100 other uses for it.... Not to mention the kids love it for looking around corners! :)
  3. ceekay
    ceekay New Member
    Ye they look pretty good I must admit, they arnt very expensive either maby thats one for the van
  4. Dreadnaught Heating
    Dreadnaught Heating New Member
    In no particular order,
    Fluke continuity tester (too many belts off leccy showers/badly fitted boxes in kitchens)
    Bosch GBH sds drill/gun, pays for itself every time I get it out of the box.
    Telegan Sprint V2 FGA with printer/thermometer clamps
    open ended spanners 6-20mm inclusive, plus 22, 24, 30/32
    BAHCO pump pliers
    Bosch Multitool
    24" stillsons
    Monument 'wriggley' tap spanner
    Basically I have a waaaaay too big/heavy FACOM carry bag that has mebbe 50 crucial tools that you just know you 'might' need to complete a task, but of course, we need more various tools than any other trade on an hourly/daily basis don't we?
    DH
  5. palavaman
    palavaman Well-Known Member
    junior hacksaw, its a must.
  6. Mountain Man
    Mountain Man New Member
    24mm open-ended spanner cut 1/4 short, and grind off some of the cheek. Ace on 15mm compression fittings.
    The Monument one is a load of tihS even though it's less than £3.
    I dunno what Monument used to get that size spanner, but it fits nothing in my well stocked van!
  7. superfurryanimal
    superfurryanimal New Member
    milwakee battery hacksaw ... thats a must fella..
  8. ceekay
    ceekay New Member
    I brought a telescopic magnet and its a gem for getting screws that you have droped where you cant get your fingers, if its a realy tight space like down the plughole put a big screw on the end and the screw becomes magnetic its even strong enough to pick up my adjustables. great stuff
  9. Sir R Puller
    Sir R Puller New Member
    Of course, no self-respecting Plumber should leave home without has Bahco wide jaw adjustable spanners, 10,15,22 & 28mm pipe slice & Nightlite LED torch.
  10. tiling spread
    tiling spread New Member
    bahco spanner and my emergency phone charger
    telescopic magnet
    lunchbox flask
    bluetooth headset dont want to get nicked
    nurofen ibuprofen redbull
    body spray stays in the van
    and a set of foot prints
  11. no comment
    no comment New Member
    ERBAUER 10.8 volt mini drill allways in box. saved many a trip to van (must have decent masonary drill kit) same battry for multi cutter as well
  12. ian anderson
    ian anderson New Member
    The Gerber pocket sharpener gets my vote. For less than the cost of a pint, this tiny tool keeps my every day carry knife, plenty sharp enough for work.
    Well, that and my DW743 flip saw of course. Opposite ends of the tool spectrum for you........£3 to £600
  13. howlsatthemoon
    howlsatthemoon New Member
    bahco 6,10 and12 inch adjustables. ck 12 inch grips. aeg angle attatchment for my atlas copco hammer drill.  testo 327.
  14. NEEDAJOINTMAN
    NEEDAJOINTMAN New Member
    like the look of that sea snake will be able to find those lost maltesers ????
  15. catchup
    catchup Member
    Funny that,my missus also likes the look of my Bed snake
  16. screwfix
    screwfix Guest
    oh no.
    This conversation's heading the wrong way.
