In my house, there is bath shower mixer connected to the bath. Please advise if there is any way of changing to just taps? Will the holes in the bath be different - bigger/smaller?
Should be no problem changing from a standard bath shower mixer to single bath taps. The only problem is the single taps can turn easily if not fitted properly. You could also consider fitting a bath mixer (one that has no shower).
