Hi all, Our toilet is letting a small but consistent amount of water into the bowl between flushes so I need to get into the cistern. However, the cistern part is a completely sealed ceramic unit down to the pan (i.e. it has no 'lid') and I'm struggling to find the model to work out how to get in. I am able to start to unscrew the flush fitting, but not sure if I can just lift it all up or if there's a proper technique. Can anyone help identify the make/brand or how to get in from the pics? Thanks!
You unscrew & remove the locking ring on flush button, you can then lift off ceramic cover revealing the inner tank. Seen one that was as above,can't recall the make,think it was Italian or German product. Here we go,see instructions in this link here,identical setup. https://www.victorianplumbing.co.uk...e-cistern-soft-close-seat?campaign=googlebase
Fantastic, thank you @KIAB Looking over the instructions, am I correct in thinking I can unscrew the locking ring and lift the ceramic cover without needing to shut off the water or anything (i.e. the ceramic cover is literally sat over an independent unit)?
Hi all, Finally found some time when the whole family were out to shut down water and get into the cistern as there's a continuous slow but steady trickle of water into the pan (constant hissing sound). Have taken some pictures of what I now see - does anyone have any advice for what needs fixing and how? Feels like the blue lever is a part of it but even when i pull it fully up so it's off there is still a very small trickle. Help much appreciated
1. Isolate the water coming into the cistern. 2. Remove the flush valve (big white plastic bit in the middle). Try pushing it down slightly and turning it (gently) anti-clockwise (max. 1/4 turn, more likely 1.8th or less). They are usually on a bayonet type fitting. 3. Check the washer at the bottom of the flush valve and its seating in the bit left in the cistern for bits off grit and the washer for bubbles in the rubber. Clean grit if present. If bubbles, or anyway as you've got it apart, replace washer. 4. The inlet valve is the bit on the right, with the blue plastic float arm attached. 4a. Take the cover off the valve. (see below) 4b. Inside there will be some form of diaphragm washer. Get a new one and fit it. 5. Reassemble all and test. I'm not sure what type of inlet and flush valves they are, but the inlet looks like a Geberit Impuls 360. If so, flush valve also likely to be Geberit.
If the inlet valve is a Geberit valve and proves to be faulty then you can buy what is called the cartridge, which includes a washer seal and the blue armed part. Try toiletspares.co.uk online for identification and parts. You can also order a seal washer for the flush valve (the large middle part) from there if needed
Thank you both - will take a look at your advice later this week and report back. Appreciate your time and help.
@andy48 @Heat just wanted to let you know it was the washer at bottom of flush valve - one side had a bubble, turned it over, put it all back together and it's fixed it. Will obv need a replacement in time but at least I know how to do it now / what it was. One small note to any else using this thread, the flush valve has two clips on either side (you have to kind of reach down and feel around a bit) as opposed to twisting off via a bayonet fitting. Thanks to you both.
Must be a Geberit flush valve by the looks of it. Typical of those to have a grey rubber seal washer that does blister. You can pierce the blister if you wished. The new replacement washer is a white silicone rubber type and much better
