Hi looking for some advice. Had a new flooring laid about 14 months ago and gaps are starting to appear between the boards. Please see attached photos. Without having to take up the floor is there anyway to fix this issue.
that was t&g with "honest layer of wood glue? not possible to mend it without taking it up and having significant wastage ...
Hi it was T&G laid on as a floating floor recommended carpenter laid it as a homer who says he can do nothing about it.
Sounds like a failure of glue rather than a systemic installation error. Trouble is getting the floor up will be very awkward as those joints will be glued and you will wreck the floor lifting it.
You could try using a long sash cramp with narrow metal shims in the joints to pull it up. Whereabouts are you?
