I have an integrated washing machine. It is at the end of the run of units between two end panels (these are as yet uninstalled but not intended to be rebated at the bottom per design). How do I fit the plinth to the machine. (Hoover HBD 485D1E). Previously house (hot point wm I think) had some ironmongery which fitted on the front on the washing machine and the plinth just clipped on. The plinth needs to be able to be simply removed to access the filter and to remove and reinstall the machine for occasional servicing.
