I just tried to send a email but got a message saying it was unable to send the message .It came withe following message. You no longer have a network connection to the server.Please check your connection and try again later. Itried to send a email to wifw as well with the same result. Can anyone suggest what I meed to do.Thank's Forgot to say I am able to go into google and find what I am looking for so that works
Which E-mail program do you use? Have you recently installed a new anti-virus/firewall program or has your one updated?
Shut down your machine, then you router. Restart the router an when it's ready to go, restart your machine and try again. Outlook may have updated.
As Bazza says ! Most routers show a power, WiFi and and WLAN (internet) lights. Most also show three solid green if everything is ok. If one or more is showing amber, red or flashing, investigate cause or phone your internet provider for support
Use the web browser version of hotmail at Outlook.com OR Delete mailbox settings and reconnect As you can access Google it isn't a network thing .
I used to use Outlook, and often found after an update it wouldn't work unless I rebooted. May not work but worth a try.
If it's been a few months, the outgoing SMTP server may no longer work with your old provider. You should change that in Outlook to your new provider.
